Adding Pretty Title TO Navigation
Hi! How do I add the “pretty title” underline to active and hover menu items on the Hello Beaches Kadence theme? I want to use this color bprettytitle (teal)
There is not a way to add that particular one to it. You can try this one, but it will fade in from the top. Modify to your needs. Or you can enable the underline feature in kadence, change the color to the blue. Then in your CSS adjust the height of the underline to be a little thicker.
.main-navigation .primary-menu-container > ul > li.menu-item.current-menu-item > a:hover {
background: linear-gradient(120deg, var(–global-palette1) 0%, var(–global-palette1) 100%);
background-repeat: no-repeat;
background-size: 100% 30%;
background-position: 0 100%;
