Affiliate disclosure box
QuestionsCategory: QuestionsAffiliate disclosure box
Aries swangler asked 2 years ago
Hi I figured out how to add the affiliate box but it automatically has “om_disable_all_campaigns” is there a way to remove this in bulk? I hit delete but I have to go into each post and remove it.
Also wondering If i can have the value saved as a template and is there a way to have links in the affiliate box?
Support Team Staff answered 2 years ago
That shouldn’t be from the affiliate box.  There are other items that get added automatically in at that area when you use plugins.  Each is different and does different things.  Make sure that you should delete that before going in and deleting each one.  You can add links to the affiliate box.
