Bring block to front
I have an advanced text block that is positioned above my html code box containing my email opt-in. I decreased the bottom padding of the advanced text box because it was so far away from the opt-in and looked weird. However, it is positioned behind the html code block and cutes the text off. Is there a way to bring the advanced text box to the front using any settings or the css class field?
