Can’t get demo to load for Hello Boho
QuestionsCategory: QuestionsCan’t get demo to load for Hello Boho
Gabby McGraw asked 4 years ago
Hi, I can’t get this to load as the demo and I want to use that formatting to set up my actual site. I’m a bit of a copycat and this is the easiest way for me to visualize how things look. My site is http://www.ignitejoy.com
My file did unzip and I tried to recompress it – not sure if this caused an issue. I have a Mac
Support Team Staff answered 4 years ago
When I preview your site it does not look like you have the theme active.  Once you activate it, you can then run the setup.  Here are the setup guides on boho if it is the Kadence version
Hello Boho Setup
