Changing fonts on hello beaches
Hello
I am trying to change the fonts on hello beaches with fonts (Webfont) I bought from MyFonts. I uploaded the files to the File Manager with a FTP Manager and changed the style.css but it still won’t work.
Is there anything I can do or is the Hello Beaches Theme only compatible with Google Fonts?
Thanks for your quick response.
It is most likely not added correctly, or not added to the right spots. Can you send some screenshots to see what is happening? OR what is the URL?
I added the Webfont Files to the File Manager at wp-content/themes/hello_beaches/fonts and made a new folder.
Then I changed the style.css by adding this right underneath of the @font-face of the BrewedHereSans
@font-face {
font-family: ‘CoralBlushSerif’;
src:url(fonts/CoralBlushSerif.woff2);
font-weight: normal;
And it’s still not working. Is this the wrong place?
After you added it, did you then go through the style sheet and replace it in the spots you wanted the font to show?
Yes I did but there was still no change. Could it be that I need to make a reference to the Webfont Kit that I uploaded in the head section of the website HTML code?
If so where would I find this head section?
It would be best if we could log on and see what if happening. You can email the URL and login to support@helloyoudesigns.com
I just wrote you an email to support@helloyoudesigns.com
