Changing Portfolio Slug in Hello Blush
Is there any way to change the “portfolio” slug to something else? I’m using the Hello Blush theme and I’d like to use the portfolio feature in a different way. When I change the slug of the page to something else, the portfolio disappears and it becomes a “regular” page.
How do I change the slug to a word other than portfolio?
Please advise, thanks.
Siobhan
Unfortunately with the Portfolio Post Type plugin, you can not modify the slug. You could add another plugin to the site that will work like that portfolio archive, and then name it anything you like. Some good ones are Essential Grid, Showcase Pro and I believe Nextgen.
Thank you very much! I appreciate your time.
