Client portal set up
QuestionsCategory: QuestionsClient portal set up
Jennifer Stevenson asked 7 years ago
I can’t figure out what I’m doing wrong here. I have the Hello Boho theme and I have everything in Dubsado set up correctly, but when I get to the instructions for the widgets, the instructions for the second widget says “Second Widget – Is a Custom HTML and what you would paste your client portal script in, or your membership login shortcode.” but in my demo it has an Image widget instead.
When I put in the code into the html it just shows the code on my website. What am I doing wrong? LOL
The image widget is because I don’t actually use a client portal and needed to show what one looked like with an image. Swap that image widget out for the Custom HTML widget, then paste in your code.  It should show as a form on your site if it is the entire code.  If that does not work, shoot over your login and URL to jennifer@helloyoudesigns.com as well as the code you are trying to add and I can see what is going on.
Jennifer Stevenson replied 7 years ago
Okay, I couldn’t sort it out so I am sending you an email. Thanks!
Jennifer Staff replied 7 years ago
Just sent you back an email. It needed the entire code added. All good now.
LIsa Lizotte replied 5 years ago
Can you help me with this as well?
