Customizer does not display Widgets
QuestionsCategory: QuestionsCustomizer does not display Widgets
Cyndi Kay Green asked 7 months ago
When I try to edit the widgets for my HelloBoho theme, I keep getting this message. I am new to setting up a HelloYou theme and I am unable to find a guide to assist me in working through the different sections.
Here is the message:
The “nav_menu” block was affected by errors and may not function properly. Check the developer tools for more details.
Jennifer Staff answered 7 months ago
The classic widgets sometimes have hiccups during the import.  If you delete the nav widget and then re-add it the error message will go away.
