Double Menu
I can’t seem to figure out how to set up the 2 line menu at the top of the page.
Also, it seems like the font on my menu got really small when I changed a word. Is there a place to change the font size?
To add the menu descriptions you would open each menu item and add the wording to the Description spot. If you are not seeing that spoit, you need to enable it. Click on the settings tab in the top right corner when in the menu screen, it will pull down and you need to make sure Description is checked.
For the size, which theme is this?
Thank you, I did have to enable the description.
I’m using Hello Foxy. Am I able to change the font size? I think I need to make my font smaller b/c the menu is wrapping to 2 lines.
If you go to your style sheet on line 1981 you can adjust the size of the font for the main nav item. Then the sub menu item is line 1968. Let me know if you have any issues.
