Editing home page slider on Rosette – is it a soliloquy plugin?
I have followed the installation for the Rosette theme on a staging site – I previously had hello trending on it, but I see that soliloquy and all the extra add-on plugins are installed. I could not find a list of what plugins were needed for the new theme so I’m unsure if this requires a license for the soliloquy to run the slider…? I’m trying to get away from paying for it so I’ve been using the free version on my old site and am looking for other options… and I don’t see that the home slider has anything to do with soliloquy. I thought doing a clean install would help me figure it out, but, in short, I am confused and can’t figure out how to edit images on the home page slider.
The Rosette theme does not use a plugin for the slider. It is the built in kadence gallery feature. If you go through the demo set up of the new theme it will auto install the plugins. Kadence only uses Woocommerce, Instagram and Kadence Blocks. Which makes the site run much smoother not needing a bunch of extras.
