Embedding Pinterest Posts Adds a Large Space When Published
QuestionsCategory: QuestionsEmbedding Pinterest Posts Adds a Large Space When Published
Amanda Dunbar asked 2 years ago
I added a Pinterest component and embedded 3 pins in a single row. On the back end, there is no space below, but the pins look stretched far down. When I publish, the pins look just fine size-wise, but there is a ton of space below the pins. how do I fix this?
Support Team Staff answered 2 years ago
What is the link to preview?
Was able to find it in the blog post.  It looks to be in the code you are adding for the pins.  It has a height of 775, even though the pins are smaller.  If you would like, we can log on and take a look at the code being added, then adjust from there.  Would need login details sent to support@helloyoudesigns.com
Amanda Dunbar replied 2 years ago
Ok. I have emailed your login information for my site. I don’t have the password, but you can reset it if needed.
Just following up
