Featured Blog Image Not Showing for some Posts
I just noticed today, that the past two posts on my blog don’t show my featured image blog post. Help!
First thing of course is to double check that there is a featured image loaded for those posts. If there is, the next spot would be to see if you have jetpack installed. If so go into the jetpack settings and turn the lazyload feature off, or you can deactivate the plugin. Let me know if that does not fix the issue.
