Footer – Align Left – Kadence WP – Hello Boho
In the Footer of Kadence WP – Hello Boho, I moved all the pre-programmed contents from the Top
Row to the Middle Row. Now the Footer Widget 1, which contained the two divs of Nav Menu is aligning center, instead of left (as it was originally designed). On the preview, in Customize Footer, it shows left, but the end result is center. Would like Align Left.
It looks like there is code to make is center. Add this to your additional CSS
.site-middle-footer-inner-wrap .widget_nav_menu {
text-align: left!important;
That should adjust it. If not you can send your login details over to support@helloyoudesigns.com and we will hop on and add the code to the additional CSS.
Thank you! That worked beautifully.
Sorry one more question – How do I change the font size for text in the Nave Menu in Footer Widget?
Again would like it to look exactly like the demo version. I wish I took better notes of everything aspect of this widget before changing anything!
Sorry and thank you again!
This what we have for the top adjusted to be used in the middle
.site-middle-footer-inner-wrap ul.menu li a {
padding-top: 0.2em;
padding-bottom: 0.2em;
border-bottom: none;
text-transform: uppercase;
font-size: 14px;
letter-spacing: 2px;
.site-middle-footer-inner-wrap .widgettitle {
font-size: 1.8rem;
What is the URL to preview? So it was originally lined left and is now center?
Yes, Widget Footer 1 with Nav Menu was originally aligned left. Now aligned center. Would like to revert back to Align Left.
Here’s the URL – https://smallzer.com/contact/
Just in case – Currently only have the Coming Soon page public. Please click the “email” button” and it will take you to the contact page, where you can see the revised footer.
