Footer Not Showing Up on Hello Boss Theme
QuestionsCategory: QuestionsFooter Not Showing Up on Hello Boss Theme
Meri asked 3 years ago
Hello! I created a new footer menu (called (footer menu links) and I went to the wordpress customizer and added the footer menu links for the footer menu. I also went through Appearance, then to the footer menu and clicked the check box at the bottom that says Footer, but for some reason, it is not showing up on the website. Please advise! I need help. Thanks!
Jennifer Staff answered 3 years ago
Did you place the block in one of the footer widget areas in the customizer?
