Home Tab & Home Page
Hello. 1st thanks for all the help so far. This may be an easy fix…here is my issue:
When you type in the website address the home page displays very nicely. If you click on any other tab and then try to click on “HOME tab”, the home tab does not display the same content that I have on the home page. Instead it shows some draft content I had typed in while cleaning up the pages in the admin dashboard.
How can I get the home tab to show the same content as the home page?
It sounds like you have your “home” link going to a page, vs your actual domain. Go to Appearance > Menus > find where that item is, delete it and then add a Custom Menu item with your domain and name it home. That should fix it.
Followed your instructions and it worked. Thank you!!
