Gutenberg Editor
It shows up automatically. You have the Classic Editor plugin installed and active which overrides the new Gutenberg editor for WordPress. If you go to Plugins > Installed > find that classic editor and deactivate. Now you also have several page builders on your site, that may not work with Gutenberg. So keep that in mind if you deactivate that plugin and you find there are issues with the Tatsu or BE builders.
Ugh, this is all so confusing! lol
I had already tried deactivating Tatsu and BE and when I tried editing a page, it was a mess!
Thanks
I know, when I was trying to figure out the icons had to turn it off. It is from building each page and post with those builder shortcodes. So once you turn them off, the shortcodes no longer work.
