Header Hello Iris Blocks
I am using the Hello Iris blocks with the Orchid theme and have a few questions as it relates to the Header. I would love to make my header look like Hello Iris with the Logo to the left, nav centered, and with the Work with Me highlighted in font, but I cannot seem to make it work. The css when added to the menu does not change the font/ underline, and I can’t for the life of me seem to get the menu centered. Any suggestions? If this isn’t possible b/c I’m using blocks that’s fine too, just let me know 🙂
The block library collection doesn’t cover that. It is only the page blocks. It is something that you can add to your theme though. Can you email me the URL and a login. I’ll also need to know what color you want the underline to be, and if I’m using the same script font in your theme, or if you have a custom one loaded.
email is jennifer@helloyoudesigns.com
