Hello Beaches sales block
Is there a way to change the words on a button? I’m using a pre-formatted block and the button says “Buy Now”. I can’t find where or how to change that. I would even delete it and put in a new button, but I can’t seem to do that either.
Is this the “add to cart” button from woocommerce, or is this in a different spot? If it is the woocommerce buttons those are auto added from the plugin, and I do not believe you can change it without adding code to your functions file in the theme file that overrides the plugin settings.
