Hello Beaches: Traveling Tips
QuestionsCategory: QuestionsHello Beaches: Traveling Tips
Rendesia asked 7 years ago
Jennifer,
Thank you for helping me with the Top Posts section in my last ticket.
How can I get replicate the Traveling Tips section you have in Hello Shores?
For that one, I used the flexible widget area. Then it gets 3 widgets. The first is a Custom HTML with the widget title “The Traveling Tips”.
Second Widget – Custom HTML with this code
Then the 3rd widget is a Genesis Featured Page Advanced with a custom image that links to a page. The image was designed to look like the other sections.
I really dislike this system. It won’t let me put the code example in. What is your email, I can send you a copy of it if you would like.
Rendesia replied 7 years ago
Ah, yes please! hello@adminovative.com
Thank you very much!
dominique@txharveys.com replied 7 years ago
Please sene me this code as well. I am needing a similar setup as well. dominique@txharveys.com.
