Hello Beaches
QuestionsCategory: QuestionsHello Beaches
dominique@txharveys.com asked 7 years ago
Is it possible to get the font used for the Hello Shores version?  Also, the code for this question below as it did not save or allow you to post/reply and add.
“Thank you for helping me with the Top Posts section in my last ticket.
How can I get replicate the Traveling Tips section you have in Hello Shores?”
I’m traveling at the moment and can not for the life of me remember which font that was.  I should be back in a week or so and can give you the actual name of it.
For the travel tips section, that is a flexible widget section, with 3 widgets.
First widget – Custom HTML with title The Traveling tips
Second Widget – Custom HTML with the code
Third Widget – Genesis Featured Page Advanced with the custom image to mimic the top about section.
