Hello Blogger Block Collection – Affiliate Blocks & Instagram Feed
QuestionsCategory: QuestionsHello Blogger Block Collection – Affiliate Blocks & Instagram Feed
Jenny White asked 2 years ago
Hi there
I have the Hello Beaches template, and just purchased the Hello Blogger Block collection.
I’m having a lot of trouble working the affiliate blocks.
I’ve figured out how to add a picture of my item, but the title is laying oddly over the image (see screenshot).  I also cannot figure out what code gets put into the “your code here” section…wouldn’t I just hyperlink my affiliate code to the picture?  I’m pretty confused about how these sections work, would you mind a quick explanation / tutorial?
Also, I purchased this pack for the Instagram feed at the bottom (see screenshot) but don’t see that in any of the design elements other than one full page template – and when I add that in, the social part at the bottom doesn’t get added.  Am I missing it somewhere?
Jenny
For the affiliate stuff, usually your provider will provide code with the image and link included.  That code is what you would paste into that box and replace the “your code here” wording with.   If they do not do that and you have to load in an image and then link it with your affiliate link, then you would delete the box, and add an image block so you can upload the image to it.  Let me know if this does not help and I cna log on to your site and do an example that you can then replace with your images and code.
The footer is part of the blogger theme and not part of the blogger library collection.  The library collections are only the page sections.  If you can shoot me an email with a login to jennifer@helloyoudesigns.com and the URL, I can hop on and add that styling to your footer.
