Hello Blush – Instagram in Footer
QuestionsCategory: QuestionsHello Blush – Instagram in Footer
Jill Conyers asked 3 years ago
The appearance of Instagram in the footer has, for some reason, changed. It now displays as multiple rows with very large images. Where do I go to change the settings back to a single row with small images? The plugin, Smash Balloon Instagram Feed, says “Instagram oEmbeds are currently not being handled by Smash Balloon”. Your help would be greatly appreciated.
Scroll to the footer https://jillconyers.com/.
Support Team Staff answered 3 years ago
With the new plugin update, it makes you create a feed and then set it how you would like it to display.  After you do that, you add the feed shortcode to your widget area, or footer area and replace the old shortcode.
Jill Conyers replied 3 years ago
Thank you so much!
