Hello Blush – Shown Blog Posts
QuestionsCategory: QuestionsHello Blush – Shown Blog Posts
Tiffany Hall asked 7 years ago
Hi!
I’ve been trying to get the blog homepage to update to show more posts, but it won’t update.  I had it set before the update and now it doesn’t update.  I’ve tried changing the setting to static post but that messes with the format of the blog homepage and I’ve also tried deleting my cache.
What is a link to your site?  How may posts do you want it to show? If you would like send your URL and login to jennifer@helloyoudesigns.com and I can hop on and fix the settings.
Tiffany Hall replied 7 years ago
Hi Jennifer,
I sent you an email with the login information. Thanks for your help!
Good Morning!
I checked the posts and it’s set to 7 but it’s still only showing the 4. Is there something I can do to get it updated? Thanks!
