Hello Blush – Soliloquy Sliders (First Slider and About) and Image Section 2 (Brands I’ve Worked With)
Hello! Since my blog is image heavy, I installed the Smush plugin. After running the program. I noticed that now when you go to my site on the computer (https://thejourneyofchristine.com/) and start scrolling down, the First Image Slider adds a bunch of blank space underneath the slider (image attached)… or it won’t even show up on my mobile. All the Solioquy Sliders are not working correctly now. The slider in the About section doesn’t show up on my mobile but does sometimes show up on my desktop. The Solioquy Slider in the bottom under “The Newsletter” is also not working on mobile. Also the slider in the “Brands I’ve Worked With” section is no longer working, it keeps showing a spinning circle (GS Logos).
Thank you so much for your help!
Christine
This will happen when you have a css compressor installed, or a site speed optimizer. If you have jetpack, click to the settings and turn off the speed accelerator, and the lazy image load. If that does not fix it, we will need your login to see what other plugins you are running.
Thank you so much 🙂
