Hello Blush Text Color
I just purchased the Hello Blush theme (with installation) and have started making customizations but the text color is not updating on several sections, though it has been updated throughout the customize tool.
Sections Not Updating:
- Text on the First Image/slide section
- Text on the Menu Navigation Labels – Title Only, description updated
- Text on the “About” section
- “Join Me At” TEXT on the Simple Social Icons
- “New On The Blog” Header
- Blog Post Titles
- Navigation for blog posts
- Image Section 2 Header
- Navigation Text on the Slider in Footer 1. The hover is updated but the normal text is not.
Is there somewhere I am missing to update? I’ve gone through and changed each and every color.
From that list above, only 1 might be in the customizer. The typical colors you will find in the customizer are things that are a color, hope that makes sense, may not be wording it the best. So buttons, background colors, hover colors, links, accent text, etc.
From that list above the Navigation background color on the blog should change, it is the tan.
Did you want all of the text on the site a different color? or did you want each section to have a unique text color?
Yes, I think that makes sense. I guess I need to know what/how to change those sections. I’m hoping to change from black to a bluish gray color (#666670) throughout.
Do you want your body text that same color?
Yes!
