hello boho / opt in bar at top of home page
Hi, I am struggling to find where to edit the bar at the very top edge of the home page on the hello boho theme please? On the demo it says Call to Action. I thought it was in widgets? But if you see screen shot attached it doesn’t appear to be there (unless it forms part of that error message at the top which I’m not too sure about)
Go to Appearance > Customizer > Header > then over on the right, at the bottom you will see the different layers you have available for your header spot. It will be held in the top bar above your logo and navigation. Let me know if you have any issues editing it.
Great thank you! I had tried this before, and didn’t see it. So for anyone else looking for an answer, it’s in the section of customise header as BUTTON.
