Hello Chic Genesis Theme After Entry Widget
QuestionsCategory: QuestionsHello Chic Genesis Theme After Entry Widget
Tifany asked 3 years ago
Hi there!
One last question. I’m planning to use my blog and I can’t figure out how to delete or alter the after entry widget. I’m sure I’m overlooking something. I attached a photo.
Support Team Staff answered 3 years ago
If you go to Appearance > Widgets > you will see it listed as one of the widget areas and can delete what is in it.
Tifany replied 3 years ago
Smh! I completely overlooked that. Thank you!
