Hello Chic mobile unresponsive
QuestionsCategory: QuestionsHello Chic mobile unresponsive
Elisa Hancock asked 1 year ago
I just discovered that the changes I’ve made on my website are not showing on the mobile version. When I switched to mobile view on the backend (I didn’t even know it was possible or needed) to see if I could fix the issues, I discovered I couldn’t see any part of the website. See pic for explanation. How is it possible? Is it fixable?
Thanks
Best Answer
Jennifer Staff answered 1 year ago
You need to shrink that yoast tab and other one that is open, then you will be able to see the editing window.
Elisa Hancock replied 1 year ago
Thank you, I was able to fix it.
I still see a pink background under certain widgets even if I’ve selected a white one (only on mobile). Not sure why?
I also wanted to know how to change the appearance of the article pages. Under my article I see: correlated posts, then arrows to next and previous articles and then a banner with featured images of more suggested articles. I’ve looked everywhere and can’t find a way to take off some of it as well as the social media buttons right at the bottom of the page (I already have them on the footer and I don’t know why those extra ones are there).
Lastly I wanted to ask if it’s possible to feature specific articles on the homepage? I have the blog widget that displays the latest ones but I’m open to take that off if there’s a way to show just the few I want to highlight.
