Hello Chic Questions
I purchased the Hello Chic template. It is beautiful! I have some questions:
- I have changed the pictures and when I’m previewing the desktop the pictures are correct but when I preview tablet or phone the pictures are the ones that came with the template.
- I cannot figure out how to adjust what is on the menu bar.
- The newsletter block how do I attach it to my Mailchimp account?
I’m very novice at creating this website. I did watch the tutorial videos and have been googling and YouTubing as much as possible…but haven’t had much luck with finding many youtube videos.
Are these concerns that would normally be corrected by purchasing the “Install” or “Web Hosting”?
Thank you so much for your time!
Any image that is a parallax will have two adjustments. If you go to the setup guide, there are instructions and a screenshot of how to switch the section over to the tablet view and change the background for mobile devices.
This is 2 spots. You have your menu item options at appearance > menus. You can also assign the menu location there. The other way is if you go to the customizer, click header, then select the menu there you can change which menu is shown and the location
In your mailchimp account you can create a form, then they give you the option to add the form code to your website. It would be the html code. You copy past that into a custom html block where you would like the form to show on your site.
These are more just going through and designing the site. Not something the install would really address. Our hosting is just like traditional hosting in it provides a spot for the site to live online. It does come with a little extra help, but not really design work.
We are always here to try and help guide you any way we can.
