Hello Coach theme | front picture not loading correctly
Hi there,
I added two pictures on my front page. When I added them originally they were fine, and then I went to the site and it looks like the picture is too big. It looks like there is an over hang. I tried making the picture smaller than the recommended 1500X1200 and nothing seems to work. It happened on both pictures.
Hi there.
Here is the website http://www.leslielimardo.com.
There seems to be a piece hanging off of the top of the pictures-both the first and the middle picture. Are you saying that is supposed to be there?
When I view the site, I don’t see the piece you are talking about. Is it the orange background? That is designed to be there. Is it the gold textured part, that is from the image above that section? Is it the shadow that is behind the images?
Is it the photo in the “I designed these free gifts for you” section? If so, that was designed to stick over the top and bottom of that section. vs fitting in the color band. If you wanted it to fit in that band, I can log on and change the coding for that section so it does push above and below.
