Hello Dahlia – Header Block issue with Kadence Blocks update to 3.2.54
QuestionsCategory: QuestionsHello Dahlia – Header Block issue with Kadence Blocks update to 3.2.54
William McCue asked 1 year ago
When I upgraded to latest Kadence Blocks plugin from  3.2.53  to  3.2.54,  this Hello Dahlia theme header collection stopped displaying properly.  Example header .   When I updated the Kadence Blocks plugin from 3.2.53  to  3.2.54, the middle area of this header collection (where the text title and button is located) became more narrow, and wasn’t displaying quite right.  I checked your own theme example on your helloyoudesign.com site, and it had the same issue! I reverted my plugin back to 3.2.53 and it corrected again.
However, I see that your own site is corrected now.  (yeah!)  I also see you are running the latest plugin update.  What did you do to fix it?   I am hoping whatever the fix is, it is one line of html that I can “search and replace” in the database so I don’t have to correct 900+ separate pages worth of these headers in order to upgrade the blocks plugin.
I would really appreciate your insight.
Jennifer Staff answered 1 year ago
This is from the latest update, the right margins are not registering.  So what I did was redesign the blocks.  If you have a ton of blocks that it needs to be changed on, I would leave it.  They should fix this in the next update. I’ve sent support messages about this and I know a few others have as well.
It looks like the new kadence update fixed the right margin issue.  You should be good to update and not need to adjust anything.  Let me know if that is not the case.
