Hello Foxy Home Grid1
Hello
I started on this section and everything is working fine but the home grid 1 the image is not resizing to the selections I select from the dropdown.
It is controlled by the code for that widget spot. Before you upload an image, you would want to size it to the recommended size, then load it in. If you still have troubles you can send your URL and login to jennifer@helloyoudesigns.com and I can hop on and take a look.
Thank you so much I got it right now I’m having trouble with the padding in-between widgets. The footer 2 has a big space of white after image section 3
What is a link to your site to view it?
