Hello Niche Theme Block Library
Hello,
I’m currently having an issue with my Kadence theme for Hello Niche. I’ve been attempting to customize it through the block library however, it does not show the GUI form. I’ve made sure I’m on the latest package of PHP as well as WordPress. I’ve uninstalled and reinstalled everything as well.
Are you talking about the visual version? Right now you have it set to be the code view. You would want to change it back over to visual and you will see the actual view of the page. Or is this a different issue?
Yes, I’m looking for it to look like the visual version and not the code version. How would I change it?
