Hello Rosette – Block Library Not Importing
I currently am trying to change over my website theme to Hello Rosette on a staging version of my website and recently, the block library is not inserting any blocks to a page. I am able to edit existing blocks on the page and the library showcases all of them available, but when I click on a block to import, it does not. As with another person’s question, I have tried to reduce my website load by deactivating some plugins, but this has not helped either. Is there a way to fix this issue so that the blocks can import? Thank you!
Are you using Siteground for hosting? If so disable all the siteground plugins. If that does not fix it, please email us a login to the website so we can hop on and trouble shoot. support@helloyoudesigns.com
