Hello Rosette Testimonials
Hello,
I currently have the Kadence theme Hello Rosette. How do I edit the testimonials??
Nhi
You should be able to click right where the wording is, and then replace it with your testimonial. Then when done, you can use the arrow buttons to go to the next. Or the plus button to add another. let me know if you have any issues and I can log on and troubleshoot, or even help add your testimonials.
I figured it out. Thank you!!! 🙂
