Hello Sassafras-accent text color
Hi, I was able to change the accent text color through the customizer, but there is one section where it just will not change. I am referring to the accent text on the Home About Widget. Every other place where I have accent text it is the color that I specified on the customizer but the Home About Widget accent text remains the original color it came in when I downloaded the theme. Is there another area where I need to go set this?
No, that should be changing it. Can you email me your URL and login? I can hop on and take a look at what is going on.
Thanks. I have sent you the login information.
Hi, I sent my login yesterday. Wondering if you’ve had a chance to look into this yet? -Thanks
Never mind on this. I was able to figure it out on my own
