Help with Demo Theme Upload error
Hello, I love your design! I followed the complete set up for Hello Beauty so it looks like the demo, but the homepage grid is incomplete even though it looks like the widgets are activated. How do I fix this? http://www.privatepracticeskills.com
Sometimes the Featured Page widget does not stick properly. Go to Appearance > Widgets > and in the home grid 1 widget spot, select the About page again and click save. Then go to Home Grid 3 and select the Blog page and click save. Once you do that both of the images should show on the homepage like the demo. This is assuming that the images were able to import.
If the images are not showing after you do that, go to the actual pages and make sure that the featured image for the page is assigned. If no image is assigned, you would want to upload an image in the recommended size and save it. Once you do this, the homepage grid will display as it should.
Let me know if you have any issues.
