Help with widgets
I sent an email earlier regarding the updated theme for Hello Sassafras, I realized afterwards I had an updated version in my downloads. I redownloaded the theme and am now having the darndest time trying to get the widgets to show up on the main page. I have searched everywhere for the answer on this, I’ve checked my reading settings, which I think I have correct. When I go into the widgets section, nothing populates. Everything is empty. My website is http://www.swearygirl.com
When you ran the demo import did you run the Wie file? That is the one that sets the widgets. The demo XML only imports the content, that wie is what sets the widgets.
Yes, I ran both the Wie and XML files using the demo importer.
Can you email support@helloyoudesigns.com with the url and login. We can log on and take a look.
I reset it and reran everything. It’s fine now. Thanks!
