Home opim email subscribe is not centered
Have the Hello Beauty template and the email subscribe isn’t centered any way to fix this?
The theme is only styled to use the Genesis ENews Extended plugin. If you are using a different plugin, you would need to add styling. Then it is also designed to have a Title, body text and the outputs you see in the theme demo. Leaving off 1 or adding, more will make it not display like the demo.
I’m using the same plugin but it appears that the first name field is not appearing :/
It will not show if it is empty. Depending on who you use, will want to place their action/call in the field. For example, Mailchimp asks for FName for the first name.
is it like this for Genesis ENews Extended ?
Yes. If you view the support docs, it will give you a screenshot of exactly how the demo is setup.
I have it as the demo is setup and still nothing
Please send your URL and login to support@helloyoudesigns.com
It looks like you are using google fedburner for your subscribe box. The only way to get it to appear like the demo would be to add another input, like the first name. Otherwise the % need to be changed in the style sheet to accommodate 1 input. Do you plan on only using feedburner, or are you going to upgrade to a newsletter provider?
Thank you, appreciate that. I do plan on upgrading but just need to have it show the name field and be centered for now.
With google feedburner, I’m not sure how to do that. You may need to log on to where those are stored and see if it is something that you can add in the settings.
