How To Change Blog Post Padding
Hi, I’m hoping you can let me know where in the stylesheet I’d need to make adjustments in order to increase the padding on my blog posts.
Right now, When viewed on desktop, the text is right up against the edge of the screen, which you can see on the URL here https://samdoylecoaching.co.uk/pinterest-group-boards/ .I think it’s about 15 pixels from the edge.
Thanks so much.
