How to get HelloBoho Header on HelloRosette
QuestionsCategory: QuestionsHow to get HelloBoho Header on HelloRosette
Monica Price asked 3 years ago
Hello! I’m trying to get the look of the HelloBoho header on top of HelloRosestte but they don’t seem to be compatible. Is this something I can’t carry theme to theme? More on what I need to do: https://www.berrycast.com/conversations/5a0d8494-0e60-5e77-8081-87cc192651ab
Support Team Staff answered 3 years ago
It is something you can add.  When you click on that top row, you have to add widgets to it.  Just like in your theme.  the HTML widget and then a button widget.  Right now that top bar is blank on your clients theme.  Once you add those two widgets you can then customize them in the settings.  If you need help after adding the widgets, email support@helloyoudesigns.com with login details and then what you want it to look like.
