Instagram Feed / Footer
How do I get the IG footer as shown in the demo where it’s at the top of the footer with no padding anywhere? I have the Smash Balloon plugin but I can’t get it set up like the demo.
Please email support@helloyoudesigns.com with your url and login. Have you done the demo import? That will set up the header and footer exactly like the demo. If you did not want to do the demo import we can log on and place the footer
