Lead Magnet block – color behind text boxes/submit button
Hello, where can I change the color bg that is behind the text (name/email) boxes and submit button in the Hello Blush lead magnet block (image attached).
Let's start creating ⟶
That is from your provider. You would need to do it where you created the form. If they do not allow you to adjust that in your form settings, you may be able to add CSS to force a color change
