Linking image in grid and latest posts
I need help getting an image in my grid to link to a website. Also, I am having trouble getting my blog posts to actually show up on the page that is called blog.
For the blog page you would go to that page and make sure that the template assigned is the blog template.
Then under Settings > Reading > you would make sure that you have it set to Latest Posts and do not have a static page and blog assigned.
For the link to another page, you can use an image widget, and place the link and image in that image widget.
