Mailchimp Connection Kadence Theme
QuestionsCategory: QuestionsMailchimp Connection Kadence Theme
Meri asked 3 years ago
Hello, how to I connect Mailchimp to the current theme that I am using? I am using the Hello Boss Theme. Thank you!
Support Team Staff answered 3 years ago
There are a few ways. You can use the mailchimp plugin and place a mailchimp block or widget up. You can copy your form code into a custom html block. Or if you want a popup, you would add the pop code from mailchimp to your header or footer script area.
