Menu
You go to Appearance > Menus > then you adjust what is in the Primary, Secondary and mobile menus. After that if you want to adjust the styling that is shown, or move the menus around you go to Appearance > Customizer > Header > then you will see the menus that you can change the places, styling, etc.
Perfect! Thank you.
