menu description
I have the Hello Beaches theme. I followed the directions about enabling the descriptions selection on the menu and adding text in the description area. However, the text I entered did not populate when saved.
What is the URL to preview?
Just to clarify, do you want me to send you my website where this is happening?
Yes, so I can preview. Which navigation item should show wording above it?
https://experiencethebeach.com/
I am trying to change “Custom” above Custom Blog
I think I misunderstood. I thought it wasn’t showing. Would it be possible to log on to the site and see what is happening? If so, you can email login details to support@helloyoudesigns.com
