menu style for hello beach homepage 3
When I edited my menu I lost the menu style. How to do I get the smaller text on top in a different color? My site is http://www.snafudadventures.com The menu item, “learn more about us” I changed “me” to “us”. The menu item,”Let’s chat” I didn’t change. The other menu items I did and lost the two lines and different colors for each one.
Please help and thank you.
Sarah
Those are menu descriptions. When you open the menu item up, the little wording above the menu item is what you place in the Description box. If you do not see the description box, you have to activate it. To do this, there is a settings tab in the top right corner, it may say Screen Options, click that and then make sure the description box is checked. Once that is checked, you will be able to open each menu item and add a little description to go above the menu item wording.
