META tags missing
QuestionsCategory: QuestionsMETA tags missing
Manouk asked 4 years ago
I recently found out my meta tags are missing from my Hello Beaches design. I used another theme before (Hello Foxy) and did not have issues using my report system, but now I do because two meta tags are missing.
This is what I got from my report tool:
Your blog posts are missing 2 important META tags, “article:published_time”, and “article:modified_time”.
Something similar to these:
<meta property=”article:published_time” content=”2021-09-21T10:54:28+01:00″ />
<meta property=”article:modified_time” content=”2021-09-21T14:25:43+01:00″ />
WordPress usually ads these tags to your posts automatically.
How can I fix this?
My site: https://groetjesuitverweggistan.nl
Support Team Staff answered 4 years ago
On the backend of both themes they are the same in regards to meta properties.  Have you added a plugin that modified your outputs?
Manouk replied 4 years ago
So the theme does include these meta tags? I do not think I have any plugins which modified this, but if they are not modified by the theme I will reach out to a few of my plugins.
It might be possible this was also the case in Hello Foxy but my report tool changed what they check, so just to be sure. I have dropped in serach results since using Hello Beaches but that might be the same reason and caused by something else?
Support Team Staff replied 4 years ago
Yes, it does include those. There is nothing that is removing them on the backend. Wouldn’t think that would effect your search results. Are you using Yoast to help set the SEO and what is searched on each page?
