Mobile Columns Out Of Order
I have Rosette and I have a 3 column setup and the content goes left to right and then the next row. On mobile it displays everything top to bottom in column 1 and then column 2 and then column 3 so everything is out of order. How can I correct this to have the content show left to right.
What is the URL to the page so I can take a look and see what adjustments can be made.
This page is associated with a purchase. How do I give you access to it? https://pacificyogafit.com/members-only/ thank you.
I’m unable to view since it is set to private. There are mobile adjustments when you click on the row, then the mobile tab. Can you send a screenshot of what it looks like desktop view? Or feel free to email me a login at jennifer@helloyoudesigns.com
